Is it possible to set a Mapinfo file as 'read only' on the writer?
  • March 25, 2014
  • 6 views
Sorry if it's a simple question, but is it possible to specify that a Mapinfo file written from FME is 'read only' in the parameters?
Thanks in advance
Best answer by david_r
I do not think so. You could, however, write a Python shutdown script that does this for you.
See here for a starting point (http://code.activestate.com/recipes/303343-changing-file-attributes-on-windows/).
David
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
  • March 25, 2014
David
