Is it possible to read information (f.e. pipes) from an Autodesk dwg file to write it into a Revit-file or into the IFC-Format? Thank you in advance.
  • Jun 26, 2017 1:17 PM UTC
  • 95 views
fmelizard
Forum|alt.badge.img+22
  • Jun 26, 2017 6:15 PM UTC
Hi @eddymeyer. Have you looked at this article to help you get started: https://knowledge.safe.com/articles/595/autocad-to-ifc-conversion-example.html ?
If you require further assistance, sharing a few more details will help the FME community help you. Please reply to this thread and provide additional details including:
  • The version of FME you are using, including build number and edition
  • A small sample of your data, or screenshots of the data in the FME Data Inspector
  • A description of your expected output, with screenshots if possible
  • Your FME workspace
  • Your FME translation log file
  • Any other information that may be useful to share
@eddymeyer just adding that more work has been don on the FME Civil 3D reader in FME 2017.1 so that pipe networks and pressure pipes are now supported
