Is it possible to get multilevel tileset.json-files for pnts-files?
  • June 30, 2023
  • 11 views
The input-data are in e57-formate and we want to split them up into a huge amount of small pnts-files for using them in Cesium JS.
We need a tileset.json-file for each pnts-file. There should be an overall tileset.json-file in an superior folder listing all children tileset.json-files.
Each generated file (pnts and tileset.jsons) should not exceed a specific file size (e.g. 2 MB).
We are using version FME 2023.0. Our workbench has an e57-point-cloud-reader, a PointCloudExpressionEvaluator, a PointCloudSplitter and a Cesium-point-cloud writer.
The data are splitted by the attribute set in the PointCloudSplitter.
How is it possible to get multilevel tileset.jsons?
We already created an superior tileset.json-file and many pnts-files. The problem in this case is the big size of the generated tileset.json.
In another case many tileset.json- and pnts-file-doublets. The problem in this case is the missing tileset.json-entry-file.
virtualcitymatt
Forum|alt.badge.img+42
Check out the 3Dtiles-tools. There is a merge option there which might be helpful for you.
https://github.com/CesiumGS/3d-tiles-tools
there might be some other functions in there which are helpful as well
