Is it possible to convert shapefile to topojson?
Is it possible to convert shape file to topojson? I didn't see this format in options, but perhaps it is possible to customize in a way?
danilo_fme
Forum|alt.badge.img+45
  • July 17, 2017
Hi @jitkam, is not possible to work with topojson.
Has a link suggested Idea to implement in future Beta version
https://knowledge.safe.com/idea/18867/topojson.html
Thanks,
jdh
Forum|alt.badge.img+28
  • July 18, 2017
There is no easy solution, but you can buildup the topojson using the TopologyBuilder to create the topology, and a JSONTemplater to build up the json as per the specification https://github.com/topojson/topojson-specification/blob/master/README.md.
The easiest way to get the arc strings is probably to use the geometryExtractor as ESRIJSON and replace the word paths with arcs.
jdh
  • July 18, 2017
Alternatively, there is a javascript TopoJSON Server module you may be able to leverage in FME via the JavaScriptCaller. https://github.com/topojson/topojson-server/blob/master/README.md#topology
  • July 18, 2017
Thank you!
