Is it possible to convert multiple solids in one DWG to single OBJ file?
  • Apr 18, 2018 3:01 PM UTC
  • 110 views
Hello,
I am trying to convert a DWG file with 12 separate solids to OBJ or DAE.
The conversion is perfect, but the output is 12 separate files - is there a way to convert it into one OBJ file?
I have just found another problem I can't resolve - in AutoCAD I have 6 layers, 2 solids in each layer.
would it be possible to export each element as a separate object? (they are grouped)
I would be grateful for some help ;)
best regards
  • Apr 18, 2018 3:53 PM UTC
Hi @pietrekpong, how about using the Aggregator to aggregate all the solids into a single feature then write it into an OBJ or DAE file?
Hello!
thank You for quick reply, bless You :)
I have read the FME documentation and found this feature, but I was convinced that it will merge all the objects as one. I am working on AutoCAD MAC ;( and I could export all objects as one STL and then import them to Blender, but i want to do an assembly animation - so i need every element as separate object. It is possible with Inventor, but FME looks like could do the job, moreover, as a batch process, so much better than manually converting more than 100 models (each consisting of at least 12 individuals).
but anyway, i will try Your suggestion and for sure i will let You know! Thanks again!
