Insert Salesforce issue with related record (Sharing record)
  • Nov 13, 2024 10:12 AM UTC
  • 59 views
cnorth
Currently have a process that recieves a list of record id’s from Salesforce using HTTP callouts, the record ID include the ID of records from a custom object and the id of a number of users, we are trying to create an insert in the customobject_share to create records to give the list of userId access to the records from out custom object.
We currently are getting an error,
Salesforce Writer: Record 1 was not processed successfully: 'FIELD_INTEGRITY_EXCEPTION:invalid parent id: Parent ID:ParentId --'
The parent id is the record Id of the salesforce record we are creating a related share record against. the record exist in salesforce and in testing we have event tried hardcoding te ID of both records, and user Id with RowCause = “Manual” and Access Level = “Edit”.
The form is running as using the Salesforce reader/writer with a System Admins login details?
Thanks
hkingsbury
Forum|alt.badge.img+73
  • Nov 13, 2024 7:23 PM UTC
Based on that error it sounds like you’re not supplying the correct ID
