Insert external reference
zzupljanin
Forum|alt.badge.img+4
I've been trying too use autocad_xref_path and autocad_xref_name to insert file (another dwg) into REALDWG writer feature type. It should be basic. But it's not working. No warnings, no errors.
Did anyone succesfully managed to do that? Can you explain me what am I doing wrong
Regards,
Želimir
Best answer by daveatsafe
Hi @zzupljanin,
As well as the path and name, you will also need to create a point geometry on the Xref feature for the Xref location, and set autocad_entity to autocad_xref.
If you are setting a relative path to the Xref, please ensure that it is valid for the output file location.
Example:
autocad_entity:       autocad_xref
autocad_xref_name:    MyRef
autocad_xref_path:    c:\test\MyRef.dwg
or
autocad_xref_path:    .\MyRef.dwg
  • November 7, 2017
Maybe this link should help you.
Note that the autocad_entity must be autocad_xref.
daveatsafe
Forum|alt.badge.img+19
  • November 7, 2017
Hi @zzupljanin,
Example:
or
zzupljanin
  • November 8, 2017
daveatsafe wrote:
Hi @zzupljanin,
Example:
or
That works. Thank you. Also, can I attach image as xref?
daveatsafe
  • November 8, 2017
You can't write an Xref that points to an image. However you can write a raster feature to DWG, and FME will write both the image and create the reference within the DWG file for you. You can try this by doing a GeoTIFF to DWG conversion.
zzupljanin
  • November 9, 2017
Thanks @DaveAtSafe
But that will create png image along with dwg. Can GeoTIFF be inserted in DWG somehow?
daveatsafe
  • November 10, 2017
zzupljanin wrote:
Thanks @DaveAtSafe
Not at present. I have created an enhancement request to let you control the format of the sidecar image, and will notify you when this is available in beta.
stevenjh
  • June 17, 2019
@daveatsafe is there any update on this?
sprongandre
daveatsafe wrote:
Hi @zzupljanin,
Example:
or
hi @daveatsafe
I can't understand what the trick is. Could you post a n example file/workbench?
that would be great! :-)
Thanks!
André
daveatsafe
  • October 3, 2019
sprongandre wrote:
hi @daveatsafe
Thanks!
André
Hi @sprongandre,
Sure. Here is a simple workspace that prompts for the file to Xref into a newly created DWG file.
sigtill
Forum|alt.badge.img+24
  • October 30, 2019
zzupljanin wrote:
Thanks @DaveAtSafe
Any update on this? Would be great to just point to an existing tif/jpg/png file. @daveatsafe
daveatsafe
  • October 30, 2019
Sorry, still in the pipeline.
  • January 17, 2022
Hi @zzupljanin​ ,
Can you give me a hand setting external references to dwgs exported from fme?
I am unable to set the xref correctly. My path is set as absolute and i have binded the xref into a template dwg.
Exporting new dwg based on template gets no information about xref. My xref is another dwg with cadastral layers...
Thanks in advance. Greetings from SLO.
Miha
zzupljanin
  • January 17, 2022
Hi @miharobar​ ,
you're approach is kind of different than mine. And while it is inovative, I can't confirm or deny that it will work as expected (shoutout to Safers for concrete answer). I will test it and give you my remarks.
However, you could use my approach and basically "hardcode" referenced dwg in your fmw.
  1. Add Creator: Point with 0,0
  2. Add AttributeManager after that with attributes:
    1. autocad_entity: autocad_xref
    2. autocad_xref_name: MyRef
    3. autocad_xref_path: c:\\test\\MyRef.dwg
  3. write it to e.g. 0 layer
  4. write all data however you want
Of course, MyRef is your dwg with cadastral layers.
Please let me know if this solution suits you or if I didn't understood your problem correctly
  • January 17, 2022
it worked for me too! Thank you very much. Interesting way how to solve this problem!
I hope some FME days will be soon able to visit at Zagreb.
Miha
carlm
Forum|alt.badge.img+10
  • November 27, 2024
A
Any news about  this? 😅
saraatsafe
Forum|alt.badge.img+9
  • December 4, 2024
Hi ​@carlm, thanks for your interest! It looks like this enhancement is still in the works, but we’ll be sure to update here when we can.
I’d also like to suggest leaving a vote for this Idea; our product managers take these Ideas into account when planning the product pipeline so Community interest can help further boost this.
