In the conversion process of using the same educational model note that using the system Epsg4326 The examination is correct When adding the converter as it is in the lesson, converting from the canvas and using the reader and writer’s coordinate sys
  • Aug 21, 2022 10:36 PM UTC
  • 40 views
mohamdwassouf
In the conversion process of using the same educational model note that using the system Epsg4326 The examination is correct When adding the converter as it is in the lesson, converting from the canvas and using the reader and writer’s coordinate syste
evieatsafe
Forum|alt.badge.img+28
  • Aug 29, 2022 7:57 PM UTC
Hi @mohamdwassouf​ thanks for your question; however, I don't quite understand what your issue is quite yet. I believe if you provide more information about your issue, as well a sample dataset and a workspace, we try our best to answer your question. If your issue is impacting production you could create a support case, check out this article on How to Create a Great Support Case
