Import raster image to Postgis
  • Sep 5, 2014 9:10 AM UTC
  • 9 replies
  • 224 views
hoa_le
Hi everybody,
I have a raster image(TIFF file). I want to import it to Postgis.
How can I do?
I tried it : - Reader: read tiff file , - Writer: PostGIS Raster.
But I got error. Could you tell me please how can I do?
Thank you
  • Sep 5, 2014 9:57 AM UTC
There should be more detailed error messages above that.
Paste all the error messages.
hoa_le
  • Sep 8, 2014 3:51 AM UTC
Yes. I tried Reader from Postgis and I got it:
  • Sep 8, 2014 9:34 AM UTC
The "fme" database could be a non-spatial database. Did you create it as a spatial database (i.e. PostGIS DB)? If you didn't, you have to extend it as a spatial database at first.
If you are using pgAdmin III tool, the way described in this page would be a quickest one.
Creating a spatial database (http://www.amipci.org.mx:8080/opengeo-docs/dataadmin/pgGettingStarted/createdb.html)
hoa_le
  • Sep 9, 2014 1:39 AM UTC
Thank you. The problem is create a spatial database. I can do it :)
hoa_le
  • Sep 9, 2014 9:14 AM UTC
I imported in postgis but when I view it in inspect, I saw it has not attribute, It means it is not value. For example: temperature, I dont see value.
Could you tell me how can I do? Thanks
  • Sep 9, 2014 10:13 AM UTC
A raster has pixel values but cannot have attributes like vector features. The image looks like a geographic feature of northern Vietnam. I guess the raster have elevation as its pixel value, that's a typical use case of raster on GIS.
What kind of result do you expect?
hoa_le
  • Sep 9, 2014 10:21 AM UTC
Exactly. It's northern of VietNam :-). Thank you cared Vietnam.
I am connecting temperature image to Postgis.
When I connected, I check in inspector. I saw It has not value.
When I connect postgis to QGIS. I cant open this raster.
I saw in this example, it has Value of each pixel:
  • Sep 9, 2014 11:03 AM UTC
Solution depends on the temperature data and your requirement.
Just one example. If the data consists of points each of which has temperature as its attribute, this process might work as expected.
1) Assign temperature into z-coordinate for each point (3DForcer).
2) Create a DEM raster based on the points (RasterDEMGenerator).
3) Clip the raster by the interest area (Clipper).
4) Write the raster into the database.
hoa_le
  • Sep 10, 2014 2:13 AM UTC
Yes. My requirement is transfer Geotiff image to store Postgis.
