Image rasterize for las files
  • Apr 1, 2020 3:15 PM UTC
  • 5 replies
  • 308 views
felipeverdu
Forum|alt.badge.img+12
Hi
I am trying to convert las files into raster, for that I am using as recommended by Safe the following transformer ImageRasterizer as you can see in the attached image:
But I keep getting the same error:
ImageRasterizer (VectorToRasterFactory): 338432 input feature(s) were discarded because they were not compatible with any band in the raster. Bands with a color interpretation require vector input features with an 'fme_color' attribute. Bands with a numeric interpretation require vector input features that have Z coordinates
ImageRasterizer (VectorToRasterFactory): No valid input features. 338432 input feature(s) processed. 0 input feature(s) with invalid geometry discarded. 338432 input feature(s) not compatible with the raster interpretation discarded
ImageRasterizer (VectorToRasterFactory): A fatal error has occurred. Check the logfile above for details
jdh
Forum|alt.badge.img+41
  • Apr 1, 2020 3:19 PM UTC
Easiest solution is to set the interpretation type to UINT16 instead of Gray16.
Otherwise you need to create an fme_color attribute based on the Z value of the las features.
felipeverdu
  • Apr 1, 2020 5:23 PM UTC
Hi
@jdh, I can only find the following: so not UINT16 (unfortunately)
On the other hand, this is weird that Safe is recommending something even in the help for the transformer but it does not work properly.
Br
Feliep Verdú
jdh
  • Apr 1, 2020 5:26 PM UTC
Hi
Br
Feliep Verdú
Sorry, use it in the NumericRasterizer rather than the ImageRasterizer.
Hi @felipeverdu1, sorry to hear that you were having difficulties converting las to raster. If this still hasn't worked out for you, would you be open to share your data with us, so we could take a closer look at it for you? You could either submit a case at https://www.safe.com/support/report-a-problem/ where you can upload the file, or you can email them into if that's a preferred option. Thanks!
felipeverdu
  • Apr 2, 2020 10:31 AM UTC
Hi @alyssaatsafe
I fixed it using the input from @jdh and adjusting 2 things: NumericRasterizer with Real32 as interpretation type and and a GeoTIFF writer with 32 bits per cell.
It works pretty well now.
Thx!
Br,
Felipe Verdú
