IFC file conversion to DWG
  • Oct 10, 2018 3:01 PM UTC
  • 269 views
Hi, I'm trying to do a simple file format conversion from .IFC to .DWG however i'm experiencing some issues with the snapping points with the dwg output. What is the best way to approach this? are there any tutorials/workspaces that can help me with this?
Thank you Jon
xiaomengatsafe
Forum|alt.badge.img+11
Hi @jdbos, Could you expand on your issue a little bit, to help the rest of the community better understand the problem. (I'm having trouble envisioning how you want to snap the points, without seeing some examples)
If you have a workspace, it could be helpful to share that.
Also, often the best way to help others understand a problem, is by showing what result you are getting, and what result you want to achieve.
Thanks!
