I have installed FME Desktop 2015.1.0.2 version. When i am trying to export/import data to and from GE Smallworld, i am getting following error. It is not connecting to smallworld dataset. It is 32 bit version
  • Jun 16, 2015 12:51 PM UTC
  • 0 replies
  • 48 views
I am getting error as "Unable to login to smallworld". Following error is coming.
Creating reader for format: Smallworld 4
Trying to find a BUILTIN plugin for reader named `SWORLDSWAF'
Trying to find a DYNAMIC plugin for reader named `SWORLDSWAF'
Loaded module 'SWORLDSWAF' from file 'C:\\Program Files\\FME\\SWORLDSWAF.dll'
FME internal API version is '3.7 20150407'. The 'SWORLDSWAF' module was built with FME API version '3.6 20090807'
Opening the Smallworld Reader on dataset `.'
Smallworld Translator version: 4.3dev.6
Number of Features: 0
Parameters : 19
Connecting to Smallworld on localhost:30000 using service FME
Unable to login to Smallworld
Merged 0 schema features read from 1 datasets into 0 resulting feature types
UniversalReader -- readSchema resulted in 0 schema features being returned
Reader Parameter(0) = ><
Reader Parameter(1) = >SERVER<
Reader Parameter(2) = >localhost<
Reader Parameter(3) = >PORT<
Reader Parameter(4) = >30000<
Reader Parameter(5) = >SERVICE<
Reader Parameter(6) = >FME<
Reader Parameter(7) = >USER_NAME<
Reader Parameter(8) = ><
Reader Parameter(9) = >PASSWORD<
Reader Parameter(10) = >********<
Reader Parameter(11) = >EXPOSE_INTERNAL_TABLES<
Reader Parameter(12) = >no<
Reader Parameter(13) = >FME_DIRECTION<
Reader Parameter(14) = >SOURCE<
Reader Parameter(15) = >_MERGE_SCHEMAS<
Reader Parameter(16) = >YES<
Reader Parameter(17) = >RETRIEVE_ALL_TABLE_NAMES<
Reader Parameter(18) = >YES<
Reader Directive(0) = >RUNTIME_MACROS<
Reader Directive(1) = >SERVER,localhost,PORT,30000,SERVICE,FME,USER_NAME,PASSWORD,********,no,FME_DIRECTION,SOURCE,_MERGE_SCHEMAS,YES,RETRIEVE_ALL_TABLE_NAMES,YES<
Configuration object contents:
FME Temporary Folder: C:\\Users\\ADMINI~1\\AppData\\Local\\Temp
mapping file Line 0: `APPLICATION' `FME_WORKBENCH'
mapping file Line 1: `AUTOREG' `YES'
mapping file Line 2: `LOG_MAX_FEATURES' `-1'
mapping file Line 3: `LOG_MAX_PRECISION' `NO'
mapping file Line 4: `LOG_APPEND' `NO'
mapping file Line 5: `FME_HOME' `C:\\Program Files\\FME\\'
mapping file Line 6: `FME_SESSION_USED' `TRUE'
mapping file Line 7: `R_1_METAFILE' `SWORLDSWAF'
mapping file Line 8: `R_1_DATASET' `'
mapping file Line 9: `R_1_SERVER' `localhost'
mapping file Line 10: `R_1_PORT' `30000'
mapping file Line 11: `R_1_SERVICE' `FME'
mapping file Line 12: `R_1_USER_NAME' `'
mapping file Line 13: `R_1_EXPOSE_INTERNAL_TABLES' `no'
mapping file Line 14: `R_1_FME_DIRECTION' `SOURCE'
mapping file Line 15: `R_1__MERGE_SCHEMAS' `YES'
mapping file Line 16: `R_1_RETRIEVE_ALL_TABLE_NAMES' `YES'
mapping file Line 17: `R_1_SERVER' `localhost'
mapping file Line 18: `R_1_PORT' `30000'
mapping file Line 19: `R_1_SERVICE' `FME'
mapping file Line 20: `R_1_USER_NAME' `'
mapping file Line 21: `R_1_EXPOSE_INTERNAL_TABLES' `no'
mapping file Line 22: `R_1_FME_DIRECTION' `SOURCE'
mapping file Line 23: `R_1__MERGE_SCHEMAS' `YES'
mapping file Line 24: `R_1_MERGE_SCHEMAS' `YES'
mapping file Line 25: `R_1_RETRIEVE_ALL_TABLE_NAMES' `YES'
mapping file Line 26: `SCHEMA_TIME' `YES'
mapping file Keyword: `R_1_MERGE_SCHEMAS' occurs 1 time(s)
mapping file Keyword: `LOG_MAX_FEATURES' occurs 1 time(s)
mapping file Keyword: `AUTOREG' occurs 1 time(s)
mapping file Keyword: `R_1_FME_DIRECTION' occurs 2 time(s)
mapping file Keyword: `R_1_SERVER' occurs 2 time(s)
mapping file Keyword: `SCHEMA_TIME' occurs 1 time(s)
mapping file Keyword: `R_1_SERVICE' occurs 2 time(s)
mapping file Keyword: `LOG_APPEND' occurs 1 time(s)
mapping file Keyword: `LOG_MAX_PRECISION' occurs 1 time(s)
mapping file Keyword: `R_1_RETRIEVE_ALL_TABLE_NAMES' occurs 2 time(s)
mapping file Keyword: `R_1_PASSWORD' occurs 2 time(s)
mapping file Keyword: `FME_SESSION_USED' occurs 1 time(s)
mapping file Keyword: `R_1_METAFILE' occurs 1 time(s)
mapping file Keyword: `R_1_DATASET' occurs 1 time(s)
mapping file Keyword: `R_1_USER_NAME' occurs 2 time(s)
mapping file Keyword: `FME_HOME' occurs 1 time(s)
mapping file Keyword: `R_1_PORT' occurs 2 time(s)
mapping file Keyword: `APPLICATION' occurs 1 time(s)
mapping file Keyword: `R_1__MERGE_SCHEMAS' occurs 2 time(s)
mapping file Keyword: `R_1_EXPOSE_INTERNAL_TABLES' occurs 2 time(s)
