I have a question about columns with even and odd numbers.
  • May 7, 2020 1:23 PM UTC
  • 76 views
sorinduru
I have a question about columns with even and odd numbers. If I have two columns of even and odd postal numbers I can create a single column of addresses with even and odd numbers?
Address EVEN
Address ODD
2
5
4
7
6
9
8
11
10
13
Address (ODD and EVEN)
2
4
5
6
7
8
9
10
11
13
Forum|alt.badge.img+54
  • May 7, 2020 1:35 PM UTC
Yes, you can simply do this
bwn
Forum|alt.badge.img+26
  • May 8, 2020 1:44 AM UTC
A bit faster, because it doesn't require FME to perform any AttributeCreator calculations is to just Rename the 2 attributes to the same Name to merge them to a single Attribute of the same Name.
Like so:
