I am using a few sde readers to query a single database table at different points in time, is it possible to expose this Version From Historical Date and Time as a fme attribute?
  • Dec 3, 2021 11:34 AM UTC
  • 32 views
ew113
Participant
Forum|alt.badge.img+3
I can see it in the reader parameters (Version From Historical Date and Time), however none of the attributes stick out as the correct one to expose.
@ew113​ On the ArcSDE reader there is an Archive WHERE Clause: under the Advanced parameters. Can you try that and see if it does what you need? Warning: it uses FME date format YYYYMMDDHHMMSS
