I am trying to create an xml reader. I continue to get the errors listed below.
  • Oct 4, 2018 8:58 PM UTC
  • 321 views
I am trying to create a proof of concept. Reading a web service and then writing to a sql server db. I am using the XML format for the reader. Getting the error message below:
Starting translation...
FME 2018.0.1.1 (20180615 - Build 18312 - WIN64)
FME Home Edition (node locked-crc)
Temporary License: 265 days left.
Machine host name is: 8BCCFH2-LT
Operating System: Microsoft Windows 10 64-bit (Build 16299)
Copyright (c) 1994 - 2018, Safe Software Inc.
Safe Software Inc.
Potentially retrieving dataset 'https://www.applitrack.com/Littleton/api/AppliTrackAPI_v3.svc/Universities()' for reader
Retrieved file C:\\Users\\tgolden\\AppData\\Local\\Temp\\FME_TempFileStore_1538683504282_11704\\Universities() for reader
Creating reader for format: XML (Extensible Markup Language)
Trying to find a DYNAMIC plugin for reader named `XML'
Loaded module 'XML' from file 'C:\\Program Files\\FME\\plugins/XML.dll'
FME API version of module 'XML' matches current internal version (3.8 20180209)
XML Reader CONTINUE_ON_GEOM_ERROR is set to YES, the reader will continue upon encountering features with geometry error, these features will be output and tagged with a xml_geom_error boolean attribute
No value found for the 'XFMAP' or 'XFMAP_FEATURE_PATHS' directives, using the XRS file 'C:\\Program Files\\FME\\xml\\xrs\\xrs.xml' to determine configuration
Opening the XML reader with source dataset 'C:/Users/tgolden/AppData/Local/Temp/FME_TempFileStore_1538683504282_11704/Universities()'
The uri-map document 'C:\\Program Files\\FME\\xml\\urimap\\gml_aixm.xml' is being used to map from URI to URI
The uri-map document 'C:\\Program Files\\FME\\xml\\urimap\\gml_citygml.xml' is being used to map from URI to URI
The uri-map document 'C:\\Program Files\\FME\\xml\\urimap\\gml_inspire.xml' is being used to map from URI to URI
The uri-map document 'C:\\Program Files\\FME\\xml\\urimap\\gml_sosi.xml' is being used to map from URI to URI
The uri-map document 'C:\\Program Files\\FME\\xml\\urimap\\gml_urimap.xml' is being used to map from URI to URI
Unable to configure the XML module to read the XML dataset. No <xrs:switch> item in the xrs document 'C:\\Program Files\\FME\\xml\\xrs\\xrs.xml' matched the XML dataset 'C:/Users/tgolden/AppData/Local/Temp/FME_TempFileStore_1538683504282_11704/Universities()'
The XML format could not be determined by examination. Try entering a feature path into the "Elements to Match" parameter, specifying an xfMap, selecting an XRS, or using a more specific reader
The XML Module halted on error, see the logfile for details
Failed to obtain any schemas from reader 'XML' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more information
FME Session Duration: 5.3 seconds. (CPU: 1.7s user, 0.5s system)
END - ProcessID: 11704, peak process memory usage: 486212 kB, current process memory usage: 484984 kB
Program Terminating
Translation FAILED.
Workspace generation failed. Parameter file was C:\\Users\\tgolden\\AppData\\Local\\Temp\\FME_1538683503932_6940.
  • Oct 4, 2018 10:31 PM UTC
I'm afraid that you haven't set reader parameters appropriately yet. See this tutorial to learn how to read XML with FME: Tutorial: Getting Started with XML
