Hull Accumulator produce the following error “Cannot write a non-area feature to an area feature class”
  • Sep 4, 2019 9:59 AM UTC
  • 7 replies
  • 151 views
I created a workbench to convert an excel files records to point feature class and I need to create a polygon surrounding the point depend on a field in the attribute table, So I used the Hill Accumulator to do this but each time I choose a field in a the group by option I got an error as you can see below.
Please note that when I cleared the group by option the workbench is working fine and I got one polygon, so what did I miss in my workbench. Any Ideas to solve this?
Cheers,
Rawan
itay
Forum|alt.badge.img+19
  • Sep 4, 2019 10:11 AM UTC
Hi @rawansaleh,
Apparently the result of the HullAccumulator produces other types of geometries expected by the feature class.
You can use a GeometryFilter after the HullAccumulator and view the results before trying to write.
Itay
Forum|alt.badge.img+54
  • Sep 4, 2019 10:48 AM UTC
If there is only one feature in your group by option, then this will remain as a point, it won't be replaced by a polygon, it will then cause an error when you try and write this point to a writer that only accepts areas.
  • Sep 4, 2019 11:20 AM UTC
Hi @rawansaleh,
Itay
Than you for your answer, yes that solve my problem
  • Sep 4, 2019 11:21 AM UTC
Thank you for your answer, so do you know how I could filter those points who have only one record the create a buffer on them?
  • Sep 4, 2019 11:38 AM UTC
I would use a geometry filter to get those features that remain as points after the hullaccumulator and then send them to a bufferer to convert to polygons
  • Sep 4, 2019 1:26 PM UTC
Thanks that help!
itay
  • Sep 4, 2019 1:40 PM UTC
You are welcome, glad I could help.
