HTML to XML conversion
  • Mar 11, 2016 4:32 AM UTC
  • 5 replies
  • 174 views
parashari
I have a list of HTML files that contain tables and I want to convert those files to XML format.
I tried using a text file reader with HTMLToXHTMLConverter and XML writer. I also attempted HTMLToXHTMLConverter with creator and XML writer but didn't get the desired o/p. Is there some other way out for it? Or I am using different parameters?
Best answer by takashi
Hi @hellblazer, how about using the Text File writer?
  • Mar 11, 2016 4:56 AM UTC
parashari
  • Mar 11, 2016 5:10 AM UTC
Hi @takashi, the TextFile writer isn't accepting(red connectors) the o/p from the HTMLTo.. transformer.
  • Mar 11, 2016 5:23 AM UTC
Just enter "text_line_data" to the "Output Attribute" parameter of the HTMLtoXHTMLConverter. Alternatively, you can write the resulting XHTML document directly into a file without using a writer, if you set "XHTML Output File" to the "XHTML Output" parameter and set a file path to the "XHTML Filename" parameter.
fmelizard
Forum|alt.badge.img+22
  • Mar 11, 2016 5:31 AM UTC
Agree completely, the XML writer expects to assemble an XML output, but you already have fully formed XML. The TextLine writer is what you need. Or the techniques Takashi suggests.
parashari
  • Mar 11, 2016 5:54 AM UTC
Absolutely!!
