How to write updated metadata xml string to to ArcSDE
  • Jul 10, 2018 9:57 PM UTC
  • 66 views
After reading the metadata from SDE, the geodb_metadata_string has been updated along with a new geodb_type attribute set to geodb_metadata. How to configure the FeatureWriter or ArcSDE writer to accept metadata changes.
rahulsharma
Forum|alt.badge.img+12
@gishub, ArcSDE geodatabase stores metadata as geodb_metadata_string. Once you have updated this, you can simply connect it to FeatureWriter transformer. Geodatabase writer should handle it , or else you can expose the attribute Under Format Attribute (in FeatureWriter) and connect the output ports manually.
This article is a good resource on this subeject:
https://knowledge.safe.com/articles/22583/working-with-geodatabase-metadata-writing-to-xml.html
