How to write point features to Blocks with Autocad_od writer
  • Oct 7, 2016 1:56 PM UTC
  • 101 views
jpdenboer
I've put a autocad template file with two test blocks, a Shapefile with points and a FMW-file in a . So I hope you can seen whats going wrong. I tried to export point features to blocks with autocad_od writer because I want to save other data as Object data. This does not work! When I use de realdwg writer it is still working right.
What is wrong in the Autocad_od writer parameters?
Best answer by erik_jan
Have you tried using the DWGStyler transformer to set the block name on the points?
erik_jan
Forum|alt.badge.img+26
  • Oct 7, 2016 2:54 PM UTC
jpdenboer
  • Oct 7, 2016 3:17 PM UTC
Thank you! This solution is working well!
  • Jan 26, 2018 4:02 PM UTC
@erik_jan I have the same issue, and I did use DWGStyler to set the block name. However, the AutoCAD_OD writer does not seem to write the points to blocks. How can I write object data AND write the points to the proper block?
