How to write crs information into GEOJSON
  • Oct 22, 2020 2:15 PM UTC
  • 5 replies
  • 838 views
whkarto
Forum|alt.badge.img+14
Hi guys,
I'm struggling with getting coordinate system information in my GEOJSON file. As mentioned in documentation I've tried to add attributes json_crs_type und json_crs_properties attributes to my features, but the GEOJSON writer ignores these attributes and passes my attributes on to "properties" section of every feature.
         "type" : "Feature",
         "geometry" : {
            "type" : "Point",
            "coordinates" : [ 630533.503899999, 475902.4741000012 ]
         "properties" : {
            "json_crs_type" : "name",
            "json_crs_properties" : "LL84"
Could anylone tell me how to configure my features to get the crs information to my file like in example below?
“type”:”Feature”,
“crs”: {
“type”: “name”,
“properties”: { “name”: “urn:ogc:def:crs:OGC:1.3:CRS84” }
“geometry”:{
“type”:”Point”,
“coordinates”: [100.0, 0.0]
Thanks for helping!!
Best answer by david_r
This was my first attempt, but didn't lead to any success at all. I've specified the coordinate syetem at the GeoJSON Writer as well as on every feature, but can't get it though to the file.
After some testing it seems FME does not write the crs for WGS84 coordinates, which in fact is correct according to the standard, as WGS84 is the default coordinate system in GeoJSON.
  • Oct 22, 2020 2:29 PM UTC
Usually it is enough to simply specify the coordinate system on the GeoJSON writer, and FME will take care of the crs information for you.
However, be aware of the following note in chapter 4 of the latest version of the GeoJSON standard:
Note: the use of alternative coordinate reference systems was
specified in [GJ2008], but it has been removed from this version of
the specification because the use of different coordinate reference
systems -- especially in the manner specified in [GJ2008] -- has
proven to have interoperability issues. In general, GeoJSON
processing software is not expected to have access to coordinate
reference system databases or to have network access to coordinate
reference system transformation parameters. However, where all
involved parties have a prior arrangement, alternative coordinate
reference systems can be used without risk of data being
misinterpreted.
This means that as long as you deliver coordinates according to WGS84, the crs information is not necessary, and I would say, discouraged.
whkarto
  • Oct 22, 2020 2:37 PM UTC
misinterpreted.
  • Oct 22, 2020 3:02 PM UTC
whkarto
  • Oct 23, 2020 6:44 AM UTC
You're absolutely wright, if the coordinate system differs from LL84 the crs section appears in output file. Thanks for helping!
r_huesken
Forum|alt.badge.img+5
  • Jun 2, 2021 10:05 AM UTC
Thanks for the info. crs info is written to geojson when different crs is selected at the writer parameters. There is another switch that needs to be set, though:
GeoJsonWriterParams
