How to use Deployment Parameters in a FeatureReader to reference a Custom Resource with a local value set to a Share?
jtermaaten
We're using FME Flow 2023.1.2.
We have got a Windows Share registered as a custom resource at FME Flow, which is locally accessible as a UNC path. I'm looking for a way to reference the custom resource in such a way that it locally uses the UNC path and at FME Flow automatically uses the resource. I believe I can use Deployment Parameters for that.
When I create a Deployment Parameter and use it as part of the path in a FeatureReader, it doesn't recognize the file I'm trying to reach, though I did fill in the local value of the Deployment Parameter.
  • Deployment Parameter Value: $(FMEShare)
  • Deployment Parameter Local Value: \\computername\shared_folder\
  • Reader Path: $(FMEShare)Subfolder\file.xlsx
I tried to create an attribute _pathExcel that is set to the path I tried to fill in in the FeatureReader. Locally that worked, but at FME Flow I got this error message:
Too many recursive macro substitutions -- line currently is: `$(FMEShare)'
How can I tailor this method to get it to work? Thanks!
nielsgerrits
Forum|alt.badge.img+53
No idea how to fix this using deployment parameters, but I use a Python Scripted Parameter to do this:
VarTest = '\\\\test\\data\\...'
VarProd = '\\\\prod\\data\\...'
if FME_MacroValues.get('FME_ENGINE', '') == '':
    if FME_MacroValues.get('Omgeving', '') == 'Test':
        return VarTest
    elif FME_MacroValues.get('Omgeving', '') == 'Prod':
        return VarProd
    else:
        return ''
elif 'TEST' in FME_MacroValues.get('FME_ENGINE'):
    return VarTest
elif 'PROD' in FME_MacroValues.get('FME_ENGINE'):
    return VarProd
else:
    return ''
jtermaaten
  • April 5, 2024
Thanks for your answer, @nielsgerrits ! This approach would probably solve my challenge, but I don't really like to put a Python Scripted Parameter in each and every workspace that uses this connection.
I like the approach of deployment parameters being managed and maintained at FME Flow, it's makes life a bit easier ;-) Any other ideas?
becchr
Forum|alt.badge.img+25
  • April 5, 2024
hi @jtermaaten, do I understand correctly: the value of your DP is $(FMEShare), but what is the name of the deployment parameter?
I think the readerpath should be: $(NameOfDeploymentParameter)Subfolder\file.xlsx
This is similar to our usage of deployment parameters, which works fine here
jtermaaten
  • April 12, 2024
Thanks @becchr for your reply and great to hear your setup works fine!
Previously the name and value of the deployment parameter were identical. I have changed that to prevent future confusion ;-)
  • Name: FME_Share
  • Value: $(FMEShare) (which is the resource name at FME Flow, referring to a UNC Path)
  • Local Value: UNC Path
I did some testing and it seems I can get it to work, though I don't really understand why..
When I enter the path $(FME_Share)Test\RD_Scales.xlsx in the FeatureReader, I get an error, which indicates the local value is not used, but the default FME Flow value is used instead.
When I add an attribute containing the same path and use that attribute as Dataset in the FeatureReader, it succeeds.
The question remains: why isn't the local value being used when the Deployment Parameter is used directly in the Dataset Parameter of a FeatureReader?
