How to use CSW-Reader to get full Metadata?
  • February 17, 2023
  • 33 views
I try to use the new CSW Reader.  At the moment i only get the summary version of the metadata. I´m looking for a way to set the get-Parameters, so i can specify:
&resultType=results
&outputFormat=application/xml
&outputSchema=http://www.isotc211.org/2005/gmd
&typeNames=csw:Record
Maybe some of you has an idea.
best regards
andylicht
danilo_fme
Forum|alt.badge.img+45
  • February 18, 2023
Hi @andylicht​
Workspace_11
Results:
Version
Thanks,
Danilo
  • February 19, 2023
Thanks for the answer, it works great. But i want to use the CSW-Reader, or is it not possible to get the full metadata?
beste regards
Tim
alinamorgan
To use CSW-Reader, you will need the address of the remote server. Once you have this information, enter it into the “server URL” field in CSW-Reader. Then click on “Read Metadata” which will return all available metadata for the specified server.
  • February 22, 2023
That is right, but i only get the summary version of the available metadata and i need the full version. I also can not specify the output schema - at the moment the csw reader is not usefull for me. At the moment the workaround of danilo seems to be the best solution.
