How to Use a Single Main Folder Parameter While Allowing Different Subfolders for Each Reader in FME Workbench ?
  • May 1, 2026 6:42 AM UTC
  • 99 views
gogopotter90
Forum|alt.badge.img+14
Hello ,
n FME Workbench, I am trying to set up a workspace where multiple readers use a common main folder path.
I created a user parameter for the main directory (root folder), and my goal is for each reader to use this main path while only specifying its own subfolder.
However, when I add a new reader and configure its dataset path, it changes the same user parameter used by the other readers. As a result, all readers end up pointing to the same path, which is not what I want.
How can I configure my workspace so that:
  • One user parameter defines the main folder path, and
  • Each reader can independently define its own subfolder without affecting the others?
FME 2021
thanks in advance
Best answer by nielsgerrits
Sure :)
nielsgerrits
Forum|alt.badge.img+67
I never use classic readers so I’m not sure how this is done using those, but this is very easy to set up using FeatureReaders. Have you tried that?
Update:
Turns out not to be that hard using classic readers. Steps I followed:
  • Create user parameter $(Folder) type Folder.
  • Drag file to canvas and configure as needed.
  • Remove automatically generated parameter.
  • Correct reader source parameter using the created folder parameter to something like $(Folder)\a\test.csv
  • Repeat for every reader.
I still prefer the FeatureReaders but it does work fine.
gogopotter90
  • May 1, 2026 11:51 AM UTC
In FME Workbench, I tried to store the file path (without the main folder) in an attribute, and then use feature reader dataset include  a user parameter for the main folder.
My idea was:
  • The user parameter defines the main folder path
  • The attribute contains the remaining part of the file path (subfolder + file name)
  • Then I combine both to read the data
but also does not work in feature reader .i got error
could u please upload working fme workbench to have a look ,what i did wrong .thanks
nielsgerrits
  • May 1, 2026 12:05 PM UTC
Sure :)
