How to transpose an excel sheet, but only a couple of columns.
  • Sep 17, 2019 12:49 PM UTC
  • 62 views
mcgregrr
I have a logger output excel spreadsheet where the easting, northing, height, and sensor value are in one column but I need them each to be an independent column. So I need to add four new columns to the excel and populate them from the one column while leaving the loggercode and dateutcdate alone.
Best answer by takashi
Hi @mcgregrr, this screenshot illustrates a possible way. Hope this helps.
  • Sep 17, 2019 1:55 PM UTC
mcgregrr
  • Sep 18, 2019 7:08 PM UTC
Thank you takashi... that worked well.
