How to store folder connection credential within writter properties
  • Dec 13, 2016 12:34 AM UTC
  • 111 views
Hi all,
I'm hoping to use FME to replicate from our internal ESRI SDE (i.e. the FMW running as scheduled task sitting on our internal server) to a geodatabase that sits on a cloud server. To connect to the folder for the geodatabase I need to enter a Username and Password. As the task scheduler runs when I'm logged off the server the credentials need to be stored with the FMW rather than just a mapped network drive on Windows. Has anyone had any experience connecting to remote folders via FME or storing username/passwords within the writer properties? Some guidance would be great. I'm fairly new to FME.
Thank you :)
  • Dec 13, 2016 9:15 AM UTC
I suspect that isn't possible. You should probably see with your IT services about running FME as a domain user that has direct access to the shared folder.
mark2atsafe
Forum|alt.badge.img+59
Instead of writing directly to the cloud server you could write locally and use something to copy/push the data to there. eg write with a FeatureWriter then use the HTTPCaller to upload the file using its authentication parameters. Not sure if you can use something like file://host/path in the HTTPCaller, but it's worth a try.
Basically the Geodatabase writer might not have authentication parameters, but other cloud based transformers do.
Otherwise I'd try what David suggested about running FME as a domain user.
thank you, will try your suggestion @Mark2AtSafe. Thanks also @david_r, unfortunatly in this instance, our network admin guys have advised that direct access to that folder is not possible as it is under a different domain.
  • Dec 15, 2016 8:06 AM UTC
Would setting up an SFTP server on the other end be a possible solution?
