How to set ArcGIS Portal Feature Service settings with FME?
  • May 20, 2020 1:22 PM UTC
  • 115 views
demeird
When publishing to ArcGIS Portal the layer has some default configurations that I would like to change. For example, share to a group/everyone, disable editing and prevent the layer from being deleted.
Any ideas in how to do that using FME?
bruceharold
Forum|alt.badge.img+20
  • May 20, 2020 1:50 PM UTC
This sounds like a great enhancement and would be applicable to ARCGISONLINEFEATURES too.
debbiatsafe
Forum|alt.badge.img+24
Hi @demeird
Unfortunately, both the ArcGIS Portal and ArcGIS Online writer does not currently support allowing the user to set the capabilities of the created feature service/layer. All feature service/layer will be published with the default capabilities. You will have to post-process the feature service/layer after it is published. Other customers have mentioned they do this using a shutdown Python script.
This enhancement is being tracked as FMEENGINE-64118 and I will update this post once this enhancement has been added.
bruceharold
  • May 20, 2020 6:35 PM UTC
Hi @demeird
The ArcGIS Python API is easy to use for this workflow.
demeird
  • May 20, 2020 7:40 PM UTC
Hi @demeird
I'm using HTTPCaller with ArcGIS REST API to work around that for now, but this enhancement would be very welcomed
