How to rename a file when using filecopy to move them to a new location.
  • Jul 11, 2018 3:10 PM UTC
  • 6 replies
  • 503 views
I am reading all JPGs contained in a location (including subfolders) and manipulating the attributes. Then, using the filecopy writer, I am moving them to a new location. I am having a hard time getting them to move with the name I am defining in the Text Editor. The original name is retained every time. Does anyone have some advice for me?
Best answer by jneujens
Just make sure the original input path is in the attribute filecopy_source_dataset. The folder you want to move them to should be the attribute filecopy_dest_dataset. The name of each JPEG can be whatever and should be in the attribute filecopy_dest_filename.
I recommend using an inspector just before the filecopy writer to verify that this is the case.
danilo_fme
Forum|alt.badge.img+58
  • Jul 11, 2018 3:17 PM UTC
Hi @emorris4
You can use the transformer AttributeManager and configure the attribute fme_basename like this image bellow:
Thanks,
Danilo
jneujens
  • Jul 12, 2018 8:17 AM UTC
  • Jul 13, 2018 2:23 PM UTC
Thanks for the help!
danilo_fme
  • Jul 13, 2018 2:38 PM UTC
You are wellcome :)
  • Oct 20, 2022 12:29 PM UTC
I'm struggling exactly with this same issue as the original question is.
I do get the files moved but cannot get the name updated. Having filecopy_dest_filename defined does not make any difference as to me it seems FME version 2022.1 File Copy transformer don't understand filecopy_dest_filename at all!?
imageAs you see, in the File Copy transformer I only get filecopy_source_dataset visible.
I've added those 2 other attributes as well but those won't make any difference.
dmerrick
  • Dec 1, 2022 12:19 AM UTC
@_jami_​  check your warnings, file copy ignores the destination file name if it does not consider the source dataset as a file. I have a workspace that works correctly because it is renaming pdf's, but another that does not work due to trying to rename a geodatabase.
