How to remove characters from JSON list?
  • Sep 6, 2021 10:53 PM UTC
  • 389 views
I'm really struggling with the string functions in FME at the moment. I have a workbench reading JSON features from an API and I have one attribute where the results are in a list. The JSON extractor results the attributes like this:
["Medium"]
Or if there are multiple values, like so:
["Easy","Advanced"]
I want the results to be:
Medium
Intermediate,Easy
I want to remove the brackets and quotes using a single transformer and can't figure out the formatting for my life! Currently I have 3 separate "string replacers", each one removing a single character, but there must be a better way...I don't mind using a REGEX expression if someone can figure it out. I'm also open to using a different type of JSON query to extract these values? If there's a way to get the attributes without the brackets and quotes?
I also tried using the string pair replacer but I constantly get an error, and I can't seem to format it properly. I wish you could enter the pairs in table format instead of one long string for replacements...would make it so much easier to figure out!
Any advice would be appreciated 🙂
Best answer by geomancer
For ["Easy","Advanced"] use
Regex_brackets_quotes_2
geomancer
Forum|alt.badge.img+70
  • Sep 7, 2021 5:59 AM UTC
Edit: The original question asked how to process ["Intermediate"],["Easy"]
in a StringReplacer in regex mode does the trick. The brackets need to be escaped.
  • Sep 7, 2021 6:08 AM UTC
Thanks for your response! Apologies, I did mess up a bit in my question though...the input is ["Easy","Advanced"] I've just updated in the question...
Your expression works but doesn't remove the inner quotes. I'm no regex expert so I still have no idea how to fix this unfortunately. If you know how to remove the inner quotes as well that would be great!
geomancer
  • Sep 7, 2021 6:16 AM UTC
  • Sep 7, 2021 10:51 PM UTC
Yes this worked, thank you!
