How to read XML with GML geometry inside
  • May 6, 2020 3:53 PM UTC
  • 160 views
gianpiero
Hello,
I have a XML file with a GML geometry inside (in attach). Moreover I have the XSD file (named: CensusTechSheet).
Can I read that file with FME? I suppose: yes. But someone can suggest me how can I do this?
Regards
Gianpiero
erik_jan
Forum|alt.badge.img+26
  • May 6, 2020 4:18 PM UTC
You can use the XML reader and then take the GML part and create a geometry from it using the GeometryReplacer transformer.
That transformer reads a geometry definition from an attribute and creates the geometry.
It has a GML definition option.
Hope this helps.
itay
Forum|alt.badge.img+19
  • May 6, 2020 4:31 PM UTC
In addition to erik answer the xml reader will create a xml_fragment attribute that holds the xml element, you can use that in the geometry replacer transformer.
gianpiero
  • May 7, 2020 6:41 AM UTC
Erik and Itay thanks for your reply.
Gianpiero
