How to read csv from a URL?
  • November 30, 2018
  • 103 views
nicholas
Forum|alt.badge.img+13
I want to read a csv from a URL, but I am failing to connect.
I add a Reader
Format: CSV (Comma Separated Value)
Dataset: http://www.bom.gov.au/fwo/IDQ60801/IDQ60801.94418.axf
under Parameters
Delimiter Character: ,
Field Names Line: 20
Data Start Line: 21
but I get the error
CSV reader: Failed to open file 'http://www.bom.gov.au/fwo/IDQ60801/IDQ60801.94418.axf' for reading. Please ensure that the file exists and you have sufficient privileges to read it
When I use chrome to visit the URL I succeed. The URL and resulting csv file definitely exist.
What I want is to read (and process) the csv file using FME
Best answer by nicholas
Solved it.
I had to set up the network proxy in Tools | FME Options | Network Proxy
I chose "Use system proxy settings"
I ticked "Proxy Server Requires Authentication"
and entered my internet logon and password
Authentication Method was basic.
This got me through my organisation's proxy server
Obviously may be different for other users
fmelizard
Forum|alt.badge.img+19
  • November 30, 2018
Hi @nicholas It works for me. Can you attach your workspace here or else send it to https://www.safe.com/support/report-a-problem/ ? Thanks!
nicholas
  • December 3, 2018
Hi DanAtSafe
I cannot attach a workspace as I cannot even create a workspace.
When I attempt to insert a reader into the blank workspace, it fails to insert the reader.
The final error line is Workspace generation failed.
nicholas
  • December 3, 2018
I work in a government department.
Do I have to configure my internet connection for a proxy server?
I assumed that as I can access the file via an internet browser, that my internet connection was fine. But maybe there is some more configuration I should be doing?
nicholas
  • December 3, 2018
Solved it.
