How to read a value from an ECW file?
  • Aug 25, 2022 5:21 AM UTC
  • 135 views
nicholas
Forum|alt.badge.img+14
I want to use the PythonCaller to read a value from the header of an ECW file.
The value I am looking for is four characters long, starting at the position of 37.
I want to then print the value.
This is the code I have so far;
import fme
import fmeobjects
# Template Function interface:
# When using this function, make sure its name is set as the value of
# the 'Class or Function to Process Features' transformer parameter
def processFeature(feature):
 pass
# Template Class Interface:
# When using this class, make sure its name is set as the value of
class FeatureProcessor(object):
 def __init__(self):
  pass
 def input(self,feature):
  print ('start')
  n = feature.getAttribute('fme_dataset')
  print (n)
  f = open(n,'rb')
  f.seek(37,0)
  print(f.read(4))
  f.close()
  self.pyoutput(feature)
  print ('finish')
 def close(self):
  pass
But it does not return the value that I am expecting
nicholas
  • Aug 25, 2022 6:04 AM UTC
I am making some progress
Here is new code
import fme
import fmeobjects
  pass
  def __init__(self):
    pass
    print ('start')
    file_name = feature.getAttribute('fme_dataset')
    print (file_name)
    ecw_file = open(file_name,'rb')
    ecw_file.seek(57,0)
    datum_string = ecw_file.read(9).decode('ascii')
    print('datum')
    print(datum_string)
    ecw_file.seek(73,0)
    projection_string = ecw_file.read(9).decode('ascii')
    print('projection')
    print(projection_string)
    ecw_file.close()
    print ('finish')
  def close(self):
    pass
nicholas
  • Aug 26, 2022 1:06 AM UTC
Here is new code
import fme
import fmeobjects
  pass
  def __init__(self):
    pass
    print ('start')
    print (file_name)
    ecw_file.seek(57,0)
    print('datum')
    print(datum_string)
    ecw_file.seek(73,0)
    print('projection')
    ecw_file.close()
    print ('finish')
  def close(self):
    pass
Code improved with a "with" statement
import fme
import fmeobjects
  pass
  def __init__(self):
    pass
    print ('start')
    print ('file')
    print (file_name)
    with open(file_name,'rb') as ecw_file:
      print('datum')
      ecw_file.seek(57,0)
      print(datum_string)
      print('projection')
      ecw_file.seek(73,0)
    print ('finish')
  def close(self):
    pass
  • Aug 29, 2022 7:54 AM UTC
Your code only prints the character it read from the file, it does not send it back to the workspace. For this you can replace these two lines:
With this single line:
feature.setAttribute('projection_string', ecw_file.read(9).decode('ascii'))
You'll have to manually expose the attribute "projection_string" in the PythonCaller.
PS, next time can you please post Python code using the Code Snippet formatting tool, it's much, much easier to read that way.
