How to Pass input to ODBC Reader
  • Sep 25, 2019 11:52 PM UTC
  • 55 views
I am building a process flow that moves data from point A to B. I noticed the ODBC reader has faster speed over SQL Executor. The challenge is the ODBC reader doesn't have inputs as incoming initiator like SQL Executor. Is there a way that I can use tow ODBC readers one execute after the other receiving inputs?
oscard
Forum|alt.badge.img+23
  • Sep 26, 2019 5:35 AM UTC
Have you tried a FeatureReader? I think that could work.
  • Sep 26, 2019 5:56 PM UTC
Thanks for letting me know about feature reader. I tried using that and noticed it doesn't give you option to limit feature attributes. Basically it is picking all columns. On top that, I was not able to see reading speed different from SQL creator and executor.
jovitaatsafe
Forum|alt.badge.img+11
Hi @abelc,
Have you tried specifying Constraints on the FeatureReader? In particular there's the Feature Types to Read if applicable, or you could try specifying the WHERE clause. There's also a parameter in the Attribute and Geometry Handling where you can choose the accumulation mode on the attributes. There's a good description in the FeatureReader parameters here which contains examples for the WHERE clause, if you'd like to take a look. Hope that helps!
