How to obtain a qgis drawing of a complex geometry ?
  • June 23, 2018
  • 19 views
I have a file written with some gml description of geometries. One of these description contains <gml: arcbycenterpoint > definition.
I tried to import this file in QGIS 3 directly. But it doesn't work. It seems that the <gml : arcbycenterpoint > is not supported but i'm not sure with this point.
I would like to know how to draw my geometries in QGIS 3.
Should i have to translate my file in an other format ?
It's an AIXM 5 format.
Thanks
soeren
  • June 25, 2018
Hi Philippe,
it is possible that QGIS is not able to handle arcbycenterpoint. You could use FME to replace the arcbycenterpoint geometries with more common gml representations by stroking the arcs and writing them as normal lines for example.
