how to know the value of nodata of a geotiff image?
  • February 12, 2013
  • 9 views
Do you know how to get the value of the nodata of a geotiff image?
Thanks
fmelizard
Forum|alt.badge.img+19
  • February 13, 2013
Open the raster in the data inspector or universal viewer, drag a box with the mouse, that should prvide you with the properties of the raster including the no data value per band.
Hope this hepls.
Hello Carto30,
you could also use the RasterBandPropertiesExtractor. If there is a NoData Value per Band it will be presented. Moreover you can use the NoData Value as an attribute, to work with that.
Best regards,
Stefan
  • February 13, 2013
Thanks for your help
