How to join multiple shp files with common field?
  • Nov 2, 2017 9:56 PM UTC
  • 41 views
Hello,
I have 3 shp files which I need to join
File 1
Postal code and name
File 2
Admin code and name
File 3
Admin code and state
Name in File 1 and File 2 has identical list
Admin code in File 3 is first two digits of Admin code in File 2
I need to create single file which would have the Postal Code, Name and State.
I tried to create Reader for File 1 and a Reader for File 2 and write them into the same file. The transaction was successful, however it first listed all items from File 1 and below all items from File 2.
Best answer by jdh
You need to use a FeatureMerger to join two streams of data together.
Use a substringextractor on the admin code in file 2, so that you have the same value as File 3.
One FeatureMerger with File 1 as requestor and File 2 as supplier, on name.
The merged output of that goes into a second featureMerger with File 3 as the supplier on Admin Code (truncated)
jdh
Forum|alt.badge.img+41
  • Nov 2, 2017 10:15 PM UTC
