how to inspect on workbench and get attribute lists from oracle non spatial file
  • Feb 21, 2020 5:49 PM UTC
  • 35 views
gogopotter90
Forum|alt.badge.img+14
could i ask how to get the list of attributes from oracle non spatial.
iam a little bit confused from oracle files .i added a reader for oracle non spatial but i could not check the oracle on inspector when i conenct with inspector i see nothing,is there a way to inspect it while iam working on workbench .
and when if i want to extract only the attributes ,how could i do that
i want to extract the attributes in table
Thanks in advance
erik_jan
Forum|alt.badge.img+26
  • Feb 21, 2020 6:31 PM UTC
Oracle Non Spatial (and any non spatial format) will show no data in the map.
But if you switch the Data Inspector to the Table View (button on the top) you should see the attributes and values.
Hope this helps.
