How to insert image into excel files by FME2014?
  • Aug 15, 2017 2:26 PM UTC
  • 5 replies
  • 123 views
@MarkAtSafe
Best answer by trentatsafe
Hello @winters
Which build of FME 2014 are you using? This can be found under Help > About FME Workbench.
Excel images were implemented in FME 2014 B14279 and later.
I know that fme2016 can do these things (https://knowledge.safe.com/articles/33588/writing-images-to-ms-excel-spreadsheets.html),and i've read the article above, but when i do the same thing on fme2014, the excel cells only display url strings, why?
trentatsafe
Forum|alt.badge.img+7
  • Aug 15, 2017 2:41 PM UTC
Hello @winters
  • Aug 17, 2017 11:36 AM UTC
Hello @winters
thank u for your answer.
Now i'm using Build-14235 and my fmeserver2014 is also Build-14235
If i change my desktop version to FME 2014 B14279, can it be compatible to my fmeserver?
thank u again
fmelizard
Forum|alt.badge.img+22
  • Aug 17, 2017 8:14 PM UTC
thank u again
You will need to upgrade them both. The B14235 server just won't know how to do the writing you require.
  • Aug 18, 2017 2:13 AM UTC
ok,thank u
I'm about to do it.
