How to get the Scope Box geometry from Revit files?
  • Aug 17, 2026 11:48 AM UTC
  • 68 views
lennartm
Forum|alt.badge.img+3
Hi there,
I'm currently trying to find a way to unlock the geometry off all scope box options that are part of a Revit file. The main idea is to write the Revit file into a GIS format and be able to filter the overall geometry by the different scope box options. However, I can’t seem to find/get the scope box geometry (or any coördinates related to a scope box) from a Revit file. I can only find some references to the scope box names.
For testing I used the first option of Snowdon Towers - Architectural file on this page: https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-61EF2F22-3A1F-4317-B925-1E85F138BE88
In the example file there are 4 options for Scope Box settings: Views Overall, Grids, Levels or None. In Revit we can see the whole project using Views Overall, but for example with Grids the outside garage entrance is filtered out. Also we can see the geometrie of those scope boxes within Revit and the filter area it uses.
Here the two different views:
View Overall Scope Box
Grids Scope Box
I’ve tried many different settings on the Revit reader in FME, but can't find any geometry specified to these scope boxes. Only within the metadata information there are some references to the scope box names.
If anyone has any information or tips on how to unlock the scope box geometries, please feel free to let me know! - Lennart
Best answer by daveatsafe
​​Hi ​​@lennartm,
FME does not currently read the Scope Boxes from Revit files, so I have created an enhancement request for our development team (IDEA-3333), and will notify you as soon as this capability is available in beta.
vadis
Forum|alt.badge.img+14
  • Aug 17, 2026 12:44 PM UTC
Hi Lennart!
Revit reader does not seem to contain exposed geometry definitions for Scope Boxes in FME. However a simple Dynamo script can do that for you. It is rather easy to implement automatic calls to Revit models even with FME to expose scopes internally and export them as csv:s where FME could take it from there in downstream processing of your choice.
I have tried this with a sample model and quite quickly got the results. Then it is another layer of challenges to make sure how coordinates fall within the framework you are working, yet I think this is the easiest workaround if you have both Revit and FME in your lap.
daveatsafe
Forum|alt.badge.img+24
  • Aug 18, 2026 5:43 PM UTC
​​Hi ​​@lennartm,
