Hello,
I'm trying to get rotation information of a cell which come from a DGN.
I found it for text element but not on cell. In microstation the information is present but not in FME, do you have any idea ?
In the help here : https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/dgnstyler.htm it say :
1OpenCell Rotation2 3Specifies rotation of the cell (in degrees counterclockwise from horizontal). This can be set to any floating-point value between -360.0 to 360.0, or be set to a value taken from an attribute.4 5Format attribute set: igds_cell_rotation
But I haven't this attribute in FME :
But here in Microstation you can see the information (50 g = 45 deg)
