how to find all point and cables in different paths between start and end point ?
  • Mar 22, 2024 10:39 AM UTC
  • 7 replies
  • 320 views
soly
Forum|alt.badge.img+3
Hello ,
i have too many points
I would like to find the points and lines between start of path and end of path in different paths ?
i would like to have excel file that include
First row Start point (a) - next point (b)- lines (line id 1)
Second row From b point - next point C - lines (line id 2 )
and so on till end point (blue point )
fllow direction from start point to end point as picture
fme 2021
thanks in advance
kailinatsafe
Forum|alt.badge.img+24
Hello @soly, thanks for posting! May I ask what format the source/input data is currently in? (eg. what format reader is being used?)
Are we working with a combination of lines and points, or just lines? Also, is the data spatially aware? (eg. does it belong to a geographical area or coordinate system?).
Further, the image shows two End Points. Should there be a path between every point and both end points? Also, do the points also have IDs? Happy to help, Kailin.
soly
  • Mar 25, 2024 7:06 PM UTC
It is file geodatabase and .every point has his own id .
i have point data and also lines ,it has coordinate system .the paths is shown explained as picture .
Do you have any suggestion?
kailinatsafe
Hey @soly, you can try using a TopologyBuilder to relate the points to the line(s) that they intersect. Otherwise, could you try building paths, then using the ShortestPathFinder to identify routes from start to finish. The result of the ShortestPathFinder is an actual IFMEPath, which could be split up into the records for XLSXW.  Ideally there would be just one path between the points. There are some great examples of how to use the ShortestPathFinder in the linked article! Hope this helps, Kailin.
soly
  • Mar 26, 2024 6:12 PM UTC
@kailinatsafe
thanks for reply ,but what should I do if there are more than one path from start point to end point .
how could I get all paths ?
kailinatsafe
Hello @soly, you would likely need to create a separate path for each start feature, then calculate their own shortest paths! Kailin.
soly
  • Mar 27, 2024 3:46 AM UTC
@kailinatsafeThanks ,i will try to do it .the problem ,it means I have to use shortest path finder more than one time and I am not sure how many paths that I have .
i have read article about first depth search ,to trace the paths but I am not sure how could I use here .Do you have FME workspace template for using first depth search to understand the logic ?
kailinatsafe
Hello @soly, I have not tested this, but I might use the TopologyBuilder to identify the Start and End points of each pathway. Next, we would need to create the line/path geometry between the Start and End points, perhaps a LineBuilder could be used. Once the line is created, you can send it to the ShortestPathFinder as the ‘From-To’ input. Check out Example1.fmwt from the Shortest Path Tutorial! Consider sharing a workspace template if you are still having issues! Happy to help, Kailin.
