How to edit CAT reader parameters after I creating new one.
  • Jul 19, 2024 8:51 PM UTC
  • 5 replies
  • 176 views
parkerr
Forum|alt.badge.img+4
I have created over 200plus parameter fields and the alignment is off but can’t edit them. Not sure how to do this. I’m new to FME Workbenches and can’t see a way to update this. I’m using the CAT so that these fields can be ran into ArcGIS Pro. I have a huge workbench and not sure what to do next. I would love any help.
Best answer by ali-safe
Hey, @parkerr.
No worries! Apologies about that. Looked into it with my team and it should be accessible under the ‘Navigator > Reader > Update Reader...’. Let me know if this works!
Thanks,
ali-safe
Forum|alt.badge.img+24
  • Jul 22, 2024 4:27 PM UTC
Hi, @parkerr.
Thanks for posting your question. Sorry that you’ve been having some trouble editing the CAT reader parameters. To edit a readers’ parameters, navigate to the CAT reader and click on it. There should be a context menu that pops up above the reader. From there, click the ‘cylinder with the gear icon’ (image below) and it should bring up the parameters. Hope this helps out! If not, don’t hesitate to reach out, happy to help!
parkerr
  • Jul 22, 2024 6:10 PM UTC
Hi there! Thank you for the image, but that did not give me the editable Field Boundaries so that I and edit the filed boundaries. That is what I need I believe.
ali-safe
  • Jul 22, 2024 7:18 PM UTC
Hey, @parkerr.
Thanks,
parkerr
  • Jul 22, 2024 9:21 PM UTC
Yes that was it! Thank you so much!
ali-safe
  • Jul 22, 2024 9:27 PM UTC
No problem :)!
