How to delete sde geodatabase tables and Feature Classes?
  • Apr 20, 2015 10:47 PM UTC
  • 108 views
Hi All,
I am tring to build a model that would delete all the existing tables, Feature classes and Relationship Classes in a SDE geodatabase and then copy new data from another geodatabase. is there a tool that i can use to delete the actual tables and not the records in those tables?
and a sub question, is there a way to create/update/delete domains in SDE?
thanks you!
Best answer by david_r
my preferred method would be to implement this using arcpy scripting inside e.g. a startup script.
Delete a feature class: http://resources.arcgis.com/en/help/main/10.2/index.html#//001700000052000000
Delete a domain: http://resources.arcgis.com/en/help/main/10.2/index.html#//001700000021000000
David
  • Apr 21, 2015 1:27 PM UTC
David
