How to delete Photos from folder
  • Jun 24, 2026 11:14 PM UTC
  • 48 views
mildred
Participant
I have a excel file with photo link to Fulcrum (a different app). I have to create a template with photo link from my shared resources and id from the excel. I have created the FME process successful. But there are some extra photos that are not mapped to the ID which I need to delete. Which transformer shall i apply.
Image above shows my FME process, I want to delete the 6 photos from unused supplier from my original folder. Which transformer shall i apply. and can it access my folder and Delete the photos.
j.botterill
Forum|alt.badge.img+69
  • Jun 25, 2026 1:08 AM UTC
You can use a Writer = File Copy and set it with Delete Mode
  1. Add a writer/feature writer File Copy fromat.
  2. Set File Operation = Delete.
  3. Prior to the writer, add attribute creator to populate the format
    • create   filecopy_source_dataset
    • set     @Value(your attribute / path_windows)
    • e.g. path_windows  =  C:\Temp\TestFile.png
Attribute Value
filecopy_source_dataset C:\Temp\TestFile.png
