How to define permissible values of an "Enumerated value" Property Typ of the IFCPropertySetDefinitionCreator
  • Oct 25, 2019 3:31 PM UTC
  • 83 views
i like to define the permissible values for attributs with Property Type = "Enumerated Value" defined with the IFCPropertySetDefinitionCreator. (see below)
How to set a liste of permissible values for the PropertyType "Bounded Value" ?
Is it possible to set de upper and lowerBound with FME?
The definition of the attribute value is already defined by using the attribute creator. (see below)
Test_Attribut_21 = 'Testwert 21'
Best regards
LuHu
sigtill
Forum|alt.badge.img+25
  • Oct 28, 2019 1:37 PM UTC
Can you use an AttributeValidator to do the validation before Writing?
  • Oct 28, 2019 1:44 PM UTC
right, for checking the values.
But
i like to define the permissible values in the IFC-file/IFC-schema.
