How to convert/transform a ArcGIS 10.0 Geodatabase (*.adf) Esri ArcGIS Binary Grid to a SHAPE File including feature types.
  • Dec 13, 2013 2:39 PM UTC
  • 67 views
How to convert/transform a ArcGIS 10.0 Geodatabase (*.adf) Esri ArcGIS Binary Grid to a SHAPE File including feature types?
1. I open an ArcGIS 10.0 Geodatabase (*.adf) Esri ArcGIS Binary Grid (AIG).
2. With Inspector I can analyse the Grids. It says:
Raster Point Info:
Cell Value (INT16): 653
Row and Column: 3028, 7828
Ground Location: 675689.057708
3. What I need is the Cell Value as a feature type for a Shape-File.
Does anybody know how to do that?
What I want is the SHAPE with POLYGON-Grids with the Cell Value (INT16): 653 as a feature type.
Is that so difficult?
Many thanks for any hint!!!
Best wishes, Timo
fmelizard
Forum|alt.badge.img+22
  • Dec 13, 2013 6:41 PM UTC
Hi Timo,
No its actually simple, I would use the RasterToPolygonCoercer and filter out the features with _label = 653. You can then dissolve them if needed and write them with a fanout based on the fme_basename.
Itay
