How to convert shp (point geometries) in to LAS point cloud?
  • September 19, 2017
  • 6 replies
  • 283 views
Hi @giusmaldera,
Here are a couple of resources to help get you started with this workflow:
I would highly recommend checking out these resources and then playing with the .shp reader, CoordinateExtractor and LAS writer. Happy FME-ing!
  • September 20, 2017
Hi @giusmaldera, I think you can just use the PointCloudCombiner to transform the multiple 3D point geometries into a single point cloud. You can then write it into a file with the LAS writer.
  • September 21, 2017
Thank you both! I have converted successfully a shapefile in LAS format, using this model:
I would like to have some attribute of the shapefile in the LAS file.Is this possibile?
Thank you very much
  • September 23, 2017
Thank you very much
I don't think you need to use the CoordinateExtractor here.
You can preserve attributes of individual points as components, if necessary. See the "Attributes to Preserve as Components" section in the PointCloudCombiner parameters, and also see here to learn what components the LAS format supports.
FME Readers and Writers > ASPRS LiDAR Data Exchange Format (LAS) Reader/Writer > Quick Facts
This page might also be helpful.
FME Workbench > FME Geometry Model > Point Clouds (IFMEPointCloud)
Thank you very much
Thank you takashi, I modified the model:
These are the parameters I am using:
But in the final Las I do not have those attributes :-(
Can you please help me?
Thank you
  • April 4, 2019
Thank you
HI.
I have the same problem as well. My .las file does not have the attributes of my shp file.
Did you manage to solve this problem?
Thanks!
Sebastian
