How to convert OpenDrive (.xml) to 3D SHP
  • Jul 17, 2020 6:48 AM UTC
  • 96 views
Is it possible for FME to convert OpenDrive (.xml) to 3D SHP?
itsmatt
Forum|alt.badge.img+48
  • Jul 17, 2020 7:08 AM UTC
Hi @bigapplerizzi19,
Check out the latest webinar on XML. https://www.safe.com/webinars/xml-athon-with-don-and-dean/
You should get some good tips on how to work with XML in FME.
You will need to build the translation yourself but FME will help you a lot here
Good luck!
