How to convert DWG to DGN, blocks to cells
Hi All,
I need to make a conversion from autocad to microstation. Where the layer names need to be changed. And the autocad-blocks need to convert into cells from a cell lib.
any ideas?
Best answer by redgeographics
Layer names correspond to the FME feature type names for both DWG and DGN so you can either map those manually or use an external lookup table (for example in an Excel file) which you can apply using a Joiner or, if you feel brave, a SchemaMapper.
For the blocks-to-cells, assuming you have a DGN cell library available, if you make sure to not explode the DWG blocks (that's a reader parameter) you will end up with points representing the blocks with an attribute acad_block_name (off the top of my head) holding the name. If you fill the output attribute igds_cell_name with a value based on that block name the writer will know to take that cell out of the library and place it there. You may need to doublecheck the sizing of the cells though, AutoCAD and Microstation may be handling that in a different way.
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
Forum|alt.badge.img+50
  • January 5, 2016
erik_jan
Forum|alt.badge.img+18
  • January 5, 2016
An additional property to watch is the justification. AutoCAD and MicroStation do not use the same justification methods, so your cells might shift location (a bit) if you do not use the right values.
mark2atsafe
Forum|alt.badge.img+45
  • January 5, 2016
The DGNStyler transformer will also be a great help in writing cells.
Also, check out these two articles/demos:
https://knowledge.safe.com/articles/1236/writing-d...
https://knowledge.safe.com/articles/1470/how-to-co...
fmelizard
Forum|alt.badge.img+19
  • January 7, 2016
Note -- the AttributeValueMapper OR the Joiner are handy to use to map the names of the blocks to the names of the "igds_cell_name" attribute.
