How to convert a building with texture microstation dgn file to citygml format
  • Oct 30, 2015 2:25 PM UTC
  • 154 views
I Have a building with itiff textured polygons. I want to convert that file in to citygml lod 2 format. Anyone please guide me. I am new to this FME.
fmelizard
Forum|alt.badge.img+22
  • Nov 2, 2015 5:09 PM UTC
Hi @mariselvam
Well you're certainly jumping in with both feet first ;-) The key to writing CityGML is setting the proper traits and attributes. This article shows how to do that while writing LOD 2 CityGML: https://safesoftware.cloud.answerhub.com/articles/...
The example above uses IFC as a source. In your DGN, if you have single features representing buildings already you should be able to ignore the part about creating the mesh.
Cheers,
Mita
deanatsafe
  • Nov 2, 2015 10:51 PM UTC
Hi @mariselvam
Within the same tutorial that Mita mentioned, there is an example that shows specifically how to write textures to citygml at: https://knowledge.safe.com/articles/1120/add-appea...
Regards,
Dean
  • Nov 10, 2021 3:21 AM UTC
I have to convert DGN(v8) to cityGML.
Can anyone help??
  • it should have
    • closing tags
    • Coordinates and graphical data.
Please, https://safesoftware.cloud.answerhub.com/articles/1023/bim-to-gis-basic-ifc-lod-100-to-lod-2-citygml.html is not working though.
daraghatsafe
Can anyone help??
  • it should have
    • closing tags
Hi @babin_t​
Here is the new link to the BIM to GIS tutorial, hopefully this helps if not please let us know, or create a post with some sample data for users to help you out.
