How to convert 3d gis to IFC with FME!
  • January 22, 2018
  • 170 views
I have a 3D gis file need to be converted to IFC format to analyse in Ansys. I had tried with FME, however the output files always has no geometry in it. How can I make it? Thank you
Forum|alt.badge.img+3
Really interested in this !!!
LizAtSafe
Forum|alt.badge.img+15
  • January 30, 2018
Hi @maxbuiaus, what is the format of your input file? Depending on the input format the process to translate it to IFC is different. If you could share a sample of your data with the community that would also help.
Here are some Knowledge Base articles to get you started:
-Liz
